LEASE HELP CHECK MAKER PART NAME_ UMC PART IAUC24N10S5L300_DIGIKEY PART NAME IAUC24N10S5L300ATMA1_HL
------Question for IAUC24N10S5L300ATMA1 Please Put your question below------
Dear DigiKey supplier,
We plan to buy 10K pcs of the below item from you. But maker part name of your item has some different characters with us
Attached file is the datasheet of the part we want
Could you pls help check and confirm if the part UMC request and Digikey maker part are different or not?
Kindly reply to us by 3 PM Vietnamese time today
Part code
Maker part no. at UMC FACTORY:
IAUC24N10S5L300
DIGIKEY Maker part name:
infineon-iauc24n10s5l300-datasheet-en_UMC MP using.pdf (788.5 KB)
Hello trangntq and welcome to the DigiKey TechForum.
We have this forum post that goes over Infineon suffixes.
The A would call out that it is Halogen Free and RoHS compliant.
The TM would call out that it is tape and reel.
The A1 would be an Infineon Designator.
That would indicate that IAUC24N10S5L300ATMA1 is the same as IAUC24N10S5L300, with the added information above making it an orderable part number.
Thank you so much for the explanation
