This Product Selection Guide contains information to help select products in the LED Drivers category on DigiKey.com
LED Driver Evaluation Boards are a circuit board(s) that are populated with components and used to provide a working example of a specific power circuit or device. The boards in this family provide an example of an LED driver for adjustable blinking, analog brightness, backlight, bipolar switch, boost converter, brightness control, camera flash, dimmable, constant current, and RGB control, plus many more.
SelectionCharacteristics
Current - Output / Channel: Typically this indicates the maximum current an output channel can provide.
Outputs and Type: Indicates the number of output circuits provided, and indicates presence or lack of a galvanic isolation barrier between input and output.
Voltage - Output: Typically represented by a range, this indicates the low and high voltage values the part is capable of producing on its outputs. Attempts to operate the system outside this range will result in improper behavior and potentially system damage.
Features: These are different capabilities or properties of the device such as adjustable, graphical user interface, and short circuit protection.
Voltage - Input: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Supplied Contents: Indicates items included with purchase.
Utilized IC / Part: Indicates the central integrated circuit the device is designed around.
ProductExamples
| MFR PART # | BOB-13884 |
| DIGIKEY PART # | 1568-1446-ND |
| MANUFACTURER | SparkFun Electronics |
| DESCRIPTION | LP55231 9, Non-Isolated Outputs LED Driver Evaluation Board |
| MFR PART # | IFBOARDDPGEN2TOBO1 |
| DIGIKEY PART # | 448-IFBOARDDPGEN2TOBO1-ND |
| MANUFACTURER | Infineon Technologies |
| DESCRIPTION | XDPL8220 1, Isolated Outputs LED Driver Evaluation Board |
| MFR PART # | LP8866EVM |
| DIGIKEY PART # | 296-LP8866EVM-ND |
| MANUFACTURER | Texas Instruments |
| DESCRIPTION | LP8866-Q1 6, Non-Isolated Outputs LED Driver Evaluation Board |
| MFR PART # | STEVAL-LLL011V1 |
| DIGIKEY PART # | 497-STEVAL-LLL011V1-ND |
| MANUFACTURER | STMicroelectronics |
| DESCRIPTION | LED1202 12, Non-Isolated Outputs LED Driver Evaluation Board |
MediaLinks
Videos
How to Install Emergency LED Driver with an LED Driver
Mains dimmable LED driver - NXP Semiconductors Quick Learning 6
Other Videos on LED Drivers
Articles
Using LED Driver Eval Boards to Optimize
LED Streetlight Driver Solutions Simplify Design
LED Driver Solutions for Mobile Backlighting
Innovative Solutions Simplify LED Driver Circuits
Other Articles on LED Drivers
Product Training Modules
Product Training Modules on LED Drivers
TechForum
TechForum posts on LED Drivers
