The LED Wholesalers driver BG-30W-12V is from a supplier we currently do not carry. The supply is a constant voltage output with an input of 90-264V (with a NEMA 5-15P plug) and an output of 12Vdc @ 2.5A/30W. The supply also has an ingress protection rating of IP68.
A possible alternative is Mean Well LPV-35-12, Digi-Key # 1866-3299-ND. Please verify the “IP rating, dimensions, wire leads, input, and output specs” from the datasheet https://www.meanwell.com/Upload/PDF/LPV-35/LPV-35-SPEC.PDF before ordering.
Mean Well LPV-35-12
The TechForum Cross-Reference category is for parts that Digi-Key does not sell or parts that have gone obsolete. Our Engineers and Techs have reviewed the specifications for these parts and made a recommendation for a replacement.
Though we will try our best to note any differences between the part offered and the original part, it is always suggested to review the manufacturer datasheet to ensure the part will work for your application.
