------Question for LMR-400-UF Please Put your question below------I want the LMR-400UF for 25m. Is there such an option?Also, are there any cables with N-type connectors on both ends?
Welcome to the DigiKey TechForum. Part LMR-400-UF is sold by the foot so you can order a 25 meter piece by ordering a quantity of 82 or 83 feet depending on how exact you need the cable length to be. I checked and didn’t find any options for a 25 meter cable assembly with N-type connectors on both ends.
hello,
I would like to purchase a 20-meter LMR-400UF cable.
Could you please provide the product link for ordering?
Is a standard RG-8 N-type connector compatible with this cable?
I am asking because I don’t have the proper tools to install crimp-type N connectors.
The DigiKey part number is 1946-LMR-400-UF-DS-ND. 20 meters converts to an order quantity of 66 (feet). Do you have the part number of your standard RG-8 connector ?
It’s nearly impossible to find unless one already knows about it, but there’s a Taoglas cable configuration tool available here through which one can spec & purchase coax cables that aren’t available as stock products. A similar resource exists for Molex, though I don’t see LMR400 indicated as a cable option.
This is the M-Type connector I have.
Can I use it with the LMR-400UF?
December 8
The DigiKey part number is https://www.digikey.com/en/products/detail/amphenol-times-microwave-systems/LMR-400-UF/9644068
The connector description does list RG8 LMR400 RG213 which are cable types the connector should work with so cable 1946-LMR-400-UF-DS-ND should be a good option. You can look at DigiKey part 1946-TC-400-NMC-2-ND as an option for the connector.
Please provide me with the following:
A link to LMR-400 (non-UF)
A link to LMR-240 (non-UF)
A link to LMR-200 UF
Links to N-type connectors suitable for LMR-240 and LMR-200
See here for LMR-400 cable. Here for LMR-240 cable and LMR-240 connector part 2737-RFN-1004-1SX-ND. See here for LMR-200 cable and LMR-200 connector part 2737-RFN-1000-C2S-ND
Please tell me the link for the LMR200UF, not the LMR200.
2025年12月10日(水) 1:51 Steve_Fellman via DigiKey TechForum - An Electronic Component and Engineering Solution Forum <notifications@digikey.discoursemail.com>:
Sorry, I missed the UF , The part number is DigiKey part 1946-LMR-200-UF-DS-ND
I can’t search for N-Type connectors for LMR-400 , LMR-240 and LMR-200.
Sorry, “2737-RFN-1000-C2S-ND” did not return any results
Sorry, “2737-RFN-1004-1SX-ND” did not return any results.
2025年12月10日(水) 21:21 Steve_Fellman via DigiKey TechForum - An Electronic Component and Engineering Solution Forum <notifications@digikey.discoursemail.com>:
These are “Marketplace” product and may not show for you if trying to view these outside the distribution area which may be US only for these parts.
Here are some connectors to look at:
The N-Type connector I’m looking for has this shape.
Can you please give me a direct link to the LMR-400, LMR-250, and LMR-200 connectors?
Also, could you please give me a link to the tools for crimp-type connectors?
Please review the links above that @David_1528 provided for the connectors.
The below is the tooling I had found.
LMR-400 tooling
LMR-240 Tooling
LMR-200 Tooling (1946-CT-240/200/195/100-ND)
