Locating A Replacement Mosfet(s)
I need a direct replacement for the following three mosfet: AP0203GMT, AONY36354, & QA3112.
I greatly appreciate your help.
AP0203GMT Cross option is FDMS8018.
The AONY36354 is in stock here. Currently, 2,868 pieces in stock.
Other similar ones include:
I can’t find any info for the QA3112, so no way to compare to anything we stock.
After more digging, I found a datasheet for the QA3112. Based on datasheet comparisons, the AONY36354 seems to be the best match. Please verify specifications and check for suitability before placing in your design.
Thank you so very much, both of you.
Thanks for this.
