Logic (HDL) sources licensing
Hi,
Under which license one could use the sources from:
Thanx in advance!
Zoran.Krajacevic
Hi @zoran.krajacevic most of the examples have a common license at the top of the example sources.
Regards,
Hi @RobertCNelson, thanks! But what about those without the common license? Are the copyright?
BR,
Zoran
Technically, it depends on what countries’ copyright laws you need to follow. Practically, most countries are like the USA for this aspect of copyright law.
In the USA any work not specifically released to the public domain has copyright protection. (e.g. the finger painting of a two year old child has copyright protection)
However, without a copyright notice, the copyright owner can not claim monetary damages. The owner is limited to making you stop using their work via the courts.
Hi @PaulHutch,
Thanks!
How would you classify this one:
– FileName: spi_master.vhd
– Dependencies: none
– Design Software: Quartus II Version 9.0 Build 132 SJ Full Version
– HDL CODE IS PROVIDED “AS IS.” DIGI-KEY EXPRESSLY DISCLAIMS ANY
– WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
– LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
– PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL DIGI-KEY
– BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR CONSEQUENTIAL
– DAMAGES, LOST PROFITS OR LOST DATA, HARM TO YOUR EQUIPMENT, COST OF
– PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY OR SERVICES, ANY CLAIMS
– BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF),
– ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION, OR OTHER SIMILAR COSTS.
– Version History
– Version 1.0 7/23/2010 Scott Larson
– Initial Public Release
– Version 1.1 4/11/2013 Scott Larson
– Corrected ModelSim simulation error (explicitly reset clk_toggles signal)
– Version 1.2 6/17/2022 Scott Larson
– SCLK immediately assumes the value of the CPOL input when the bus is idle
(Header from https://forum.digikey.com/uploads/short-url/alQWwVonijaM7wKNzSebFtNRHhn.vhd)
BR,
Zoran
I believe that’s intended to be a release to the public domain statement.
As far as I know, most US intellectual property lawyers will say it’s OK to use.
However some US intellectual property lawyers will say there must be a more formal statement like CC0 before you use it.
You’ll need to ask your companies IP lawyer for guidance. :frowning:
Hi @PaulHutch,
Thanks!
BR,
Zoran
