I’m looking for a product that can join 2 of WM2117-ND together. I believe it kinda looks like a Z, ive seen tham before but am currently unable to locate them. Or even a 8 pin male that doesn’t need to be mounted to a board but can except wiring.
no the only way I know of is to crimp contacts on to wire Click here
you may want to use ribbon cable like Click Here
then you have cables that are hooked together with those connectors.
But in 8 pin or 16 or 24 so i could cut them down
