Im looking for a 4pos molex male connector, its smaller than WM1018-ND. I have included a photo for reference, also will 18-24 AWG crimp pins fit? In the photo the one on the left is what im looking for, the one on the right is WM1018-nd
Any help would be greatly appreciated
Hello Tomdeister,
Without knowing the pitch and/or dimensions of the connector you require, it would be hard to know for sure what would work. If you are able to provide that we may be able to provide a more accurate option.
Although, based just on images and reducing the pitch of WM1018-ND, I did find A114406-ND that does appear to be similar. You will want to review the datasheet to confirm if the dimensions match, but if it does work it would use A14015CT-ND for contacts.
Im sorry this does look like the proper size connector but the pins are actually female, will these connectors work with female pins?
