Im looking for WM1018-ND that has female pins? Im wondering if WM1018-ND can take female pins also and which size they should be?
tomdeister
Thank you for contacting DigiKey , Part number WM1018-ND uses male contacts only , The one in the picture looks more like the ones in the links below , these can use either male or female contacts . You will have to look and see what pitch you need these are both different .
Housing https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/770843-1/187689
Contacts , https://www.digikey.com/en/products/filter/rectangular-connectors/rectangular-connector-contacts/331?s=N4Ig7CBcoIYE5QIwA5ECYA0IYBcoBYsAHASyWTADZkBOAXzqA
Thanks Craig
