Hello, I’m hoping somebody can point me in the right direction. I’m looking to rebuild these harness/connectors with all new parts wire, pins, connectors.
The wire size is 18awg and 22awg, also i believe the navy colored connector is a molex? I could be wrong.
TIA
Welcome to the DigiKey TechForum. Looks like your 4 position connector is DigiKey part WM20245-ND the associated pins for 18-24awg wire are DigiKey part WM2500-ND. As for the quick connect style you’ll need to verify the size of the tab width you need. Once you know the size you can select an option from here and a housing from here .
Thanks for your reply Steve, After going based off your part numbers, I think I found the correct 4 position. WM16259-ND, looks like its the correct color I need to match.
Also for these pins
would this be the correct one? 163081-1 for 16-18awg and 66332-1 for 20-24awg,
Thanks
