Looking for substitute for 2SC3423 and 2SA1360. Can someone please suggest the best alternative?
Thank you
Thank you
The VCEO and VBEO are close to this one: https://www.mouser.com/datasheet/2/149/fairchild%20semiconductor_2n5550-320047.pdf
Digi-Key does not have alternatives for these.
The TTA004 and TTC004 are a complementary pair with available stock thatβd probably be worth a try.
Thank you rick_1976. I ordered them. I am very confident they will work. The specs are very close to the original and the package is perfect. Thanks again!
Thank you bidrohini. Unfortunately this package will not work for me and also the pin configuration is different. The originals are ECB. Thank you, I appreciate your time.
