I need the jumper/shunt that goes with M20-9990246 ( 952-2262-ND) to connect the two pins together. I ordered M20-1060200 (952-2227-ND). It is a blank plastic that doesn’t connect the two together. what is the correct shunt part number?
Greetings,
Jumpers for 0.1" pin headers such as the 952-2262 can be found here. If you’d like a more specific suggestion, try the 952-2881-ND.
