M24308/2-3F
9 Pin Crimpable Connector Femaile (M24308/2-1F)
25 Pin Crimpable Connector Male (M24308/4-3F
25 Pin Crimpable Connector Female (M24308/2-3F)
37 Pin Crimpable Connector Male (M24308/4-4F)
37 Pin 90 Deg Bent Connector Male (M24308/24-34F)
37 Pin Straight Conector Female (M24308/23-10F)
37 Pin Straight Connector Male (M2000/24-10F)
15 Pin High Density Female ( M24308/2-11F)
26 Pin High Density Male (M24308/4-12F)
This above all part numbers i need to order on Digi key , is connectors will comes with crimping pin or need to purchase the pins extra
Welcome to the TechForum!
I was able to see those parts have pins and contacts included with these part numbers. There are TE and also ITT Cannon versions and all seem to be containing the contacts needed.
Thank you
Ryan
