Hi,
I have 2 connectors, 879-22-004-10-011101 & 878-22-004-00-011101
Do they mate each other?
Regards,
Nanjunda M
Hi,
Regards,
Nanjunda M
Hello nanjunda,
These are not mating connectors. They may match up, but both have spring contacts.
The mating connector for 878-22-004-00-011101 is obsolete, and the manufacturer recommended replacement is 54-879-20-004-00-011000-ND.
I do not see a mate to 879-22-004-10-011101, that have the magnetic inserts.
Hi David,
Thanks for the response.
Can you please suggest a combination of connectors?
Regards,
Nanjunda M
Hi nanjunda,
@David_1768 gave you the mate for the 878-22-004-00-011101 . . . the 879-20-004-00-011000.
It appears that the following are potential mates for the 879-22-004-10-011101:
878-20-004-10-011000 PCB pins
878-20-004-00-012000 Solder cup pins
Thanks for Support.
Regards,
Nanjunda M
