Hello to all,
im trying to match my defective sensor # E2A-M12KS04-M1-B1 PNP NA. I don’t know if this item is available. i did find some that are similar but not the same. can some one guide me?
Thank you.
Hello to all,
Thank you.
Hello and welcome to the DigiKey TechForum.
Looking up the provided part number led me to E2A-M12KS04-M1-B1, which appears to be obsolete.
We do have E2E-X4B1T12-M1 listed as an alternative that may work for you. It appears that the upper limit for the supply voltage is lower and it does have a tighter operating temperature.
You will want to review the Datasheet to confirm if this will work for your application.
The datasheet for the E2A can be found HERE.
The datasheet for the E2E can be found HERE.
