If you are looking for mating parts for the Amphenol WTF083B001 temperature sensor, here is the information you may need:
Mating Connector Options:
According to the datasheet, WTF083B001 is compatible with USCAR 3140x-2110 connectors, which are available in two variants:
- 0314022110: TE/Molex “GET” terminal system
- 0314032110: Molex 0.64mm terminal system
The manufacturer has confirmed that both options will work as long as the mating terminals are tin-plated. The choice depends on the terminal system preferred by the customer.
Cable Assemblies:
- Molex offers MX64 cable assemblies, which use 314032100 connectors without a CPA (Connector Position Assurance).
The CPA is a secondary locking mechanism that provides extra security to the connection. All connectors already have a primary locking mechanism (the finger push tab) to hold the connection in place.
A connector without a CPA can still mate and function properly with WTF083B001, but it will only rely on the primary lock for securing the connection.
Both versions, with or without CPA, are fully compatible with WTF083B001.
Please refer to the MX64 connectors document below for more details:
mx64_manual.pdf (2.7 MB)
Applicable Part Numbers
| 900-2264611023-ND | 2264611023 |
| 900-2264611022-ND | 2264611022 |
| 900-2264611024-ND | 2264611024 |
| 900-2264611033-ND | 2264611033 |
| 900-2264611062-ND | 2264611062 |
| 900-2262011022-ND | 2262011022 |
| 900-2264611034-ND | 2264611034 |
| 900-2262011023-ND | 2262011023 |
| 900-2264611032-ND | 2264611032 |
| 900-2262011032-ND | 2262011032 |
| 900-2264611063-ND | 2264611063 |
| 900-2262011024-ND | 2262011024 |
| 900-2262011033-ND | 2262011033 |
| 900-2262011034-ND | 2262011034 |
| 900-2264611064-ND | 2264611064 |
| 900-2262011062-ND | 2262011062 |
| 900-2262011064-ND | 2262011064 |
| 900-2262011063-ND | 2262011063 |
| 0314032110-ND | 2266-314032110-23 |
| WM19963-ND | 31403-2110 |
| WM19963 | |
| 314032110 | |
| 031403-2110 | |
| WM24414-ND | WM24414 |
| 31402-2110 | |
| 314022110 | |
| 031402-2110 | |
| 0314022110-ND | 2266-314022110-23 |
