Hello! I was looking into purchasing an evaluation board for the Melexis Time-of-Flight Camera Chip MLX75027. There are a few questions about part identification that are not complete with the set or described in the product manual/specifications.
The evaluation boards have the following numbers:
1: EVK75027-110-940-2 ($3,125)
2: EVK75027-70-940-2-SLM ($3,360)
3: EVK75027-110-940-2-SLM ($3,360)
4: EVK75027-140-940-2-SLM ($3,360)
The following questions are:
- What does the product identifier 70, 110, and 140 mean in the manufacturers part number? What makes them different?
- Why are the prices different between the first and 2nd-4th products different?
- Each device is said to come with an Infrared filter attached to the camera? Do the eval kits come with this? Is it possible to get a kit with the board removed?
- What does SLM mean in the manufacturer product number?
Thank you for any insight!
sashaferlic
Thank you for contacting DigiKey , I have sent these questions to the product management group to get the answers for you , when I get them I will post them here for you .
Thanks Craig
Craig,
Thanks for the heads up! Is there any update on their progress?
Sorry , still waiting on info from the manufacturer , when I get it I will post it .
Thanks Craig
sashaferlic
Sorry for the long delay here is what we got back from the manufacturer ,
Answer: 70, 110, and 140 here mean horizontal field of view. Here is the convention how we define our EVK number: EVK(melexis product number) - horizontal field of view - wavelength - version - optional adder
Answer: Different versions can entail different hardware and thus different pricing.
Answer: All EVKs have IRBP mounted in sensor lenses. Customers can mechanically remove it, but Melexis is not liable for damage of any kind thereof. A safe way is to contact the lens supplier, Naotech, to request a lens version without IRBP integrated. For 110 degree FOV, please request NL1774 for QVGA resolution and NL3605 for VGA resolution, mentioning no IRBP 38nm filter.
Answer: SLM is an optional adder that identifies a specific illumination board design.
Hi Craig,
Thank you so much for getting back to me!
I do have a couple follow-up questions:
- Does the answer to the original question 3, imply that once the lens is taken off the sensor is not covered by anything?
- Does the EVK board have a way to access a 10MHz reference or synchronization signal used by the receiver? Or another question - does the EVK board have pins to access different signals on the PCBs?
