Some solder products from MG Chemicals are sold as solder wire in the form of a spool or roll. One example is 4865-227G, which is a No-Clean Type 63/37 1/2 LB, but the datasheet does not mention the length of wire on the spool. Only its weight, half a pound.
If you want to know the wire length, you can get it by calculation. The manufacturer has provided a simple conversion tool which covers solder types from MG Chemicals.
Solder Wire Length Converter (1).xlsx (11.4 KB)
This tool enable the conversion from the weight (in grams) and diameter (in mm) from the product datasheets and it converts to a length. It would be a reference.
See Also
