MG750-200M High Voltage Resistor
MG750-200M is a Caddock Electronics resistor that is currently not stocked at Digi-Key. If you are in need of this specific resistor please contact our sales department and we can process a Special Order request for you.
If you are able to use a cross in your application part ROX150-200MF-ND is an electrical spec cross. This 200M Ohm 5W 1% through hole resistor features a tighter tolerance and slightly different physical size than the original Caddock part. See the MFG Datasheet for full details.
Vishay Dale P/N ROX150200MFKEL
If you have any question on this resistor please feel free to contact reply below or post you own question in the category that fits your needs.
