I am wanting to idenitfy this connector which is used for SOMFY motors.
Male / female housing with crimp terminal connectors.
I require the individual components so I can crimp the wires myself.
I am not familiar with this brand as one of the pictures has the logo, so hopefully should make the search or identification easier
Photo attached
Housings of that type are found here, with contacts for a given style generally being referenced as “associated product” toward the bottom of the detail page for a given part. I’ve not been able to identify one with that particular shape, but it’s possible that I’ve overlooked something. Measuring the pitch (distance between adjacent contacts) would be helpful in narrowing the field.
Hi. I’m after a set of these connectors also. Just wondering if you had any luck finding one or not? In particular I’m really after the male side (small pins, bottom left picture). I tried the link Rick_1976 posted but it just takes me to the page of molex connectors and theres heaps to choose from. If anyone can help that would be great.
Thanks
Welcome to the forum , as Rick stated we do not have this exact connector , here are the ones we have that are close , https://www.digikey.com/short/24b20rr4 you will have to change both ends if you need that exact connector you will have to contact the OEM to get a replacement .
