Monolithicpower.com hat ein Design-tool als Crossreferenz mit Alternativen für die obsolete intel Enpirion Serie zur Verfügung gestellt:
Replace your End Of Life (EOL) intel Enpirion products with a MPS Monolithic Power Solution.
| Max Iout (A) |
Vin Range (V) |
Intel Enpirion Part Number |
MPS Part Number | Monolithic Power Solution Advantages |
| 0.4 | 2.5 - 5.5 | EP5348UI | MPM3804GG-Z | 7% Higher efficiency |
| 0.5 | 2.4 - 5.5 | EP5352QI | MPM3805GQB-25-Z | 60% Smaller, PG |
| 0.6 | 2.4 - 5.5 | EP5357HUI | MPM3804GG-Z | 30% Smaller |
| 0.6 | 2.4-5.5 | EP5357LUI | MPM3804GG-Z | 30% Smaller |
| 0.6 | 2.4-5.5 | EP5358HUA | MPM3805BGQB-12-AEC1-Z | 3% Higher efficiency, PG |
| 0.6 | 2.4-5.5 | EP5358HUI | MPM3804GG-Z | 30% Smaller |
| 0.6 | 2.4-5.5 | EP5358LUA | MPM3805BGQB-12-AEC1-Z | 2% Higher efficiency, PG |
| 0.6 | 2.4-5.5 | EP5358LUI | MPM3804GG-Z | 30% Smaller |
| 0.6 | 2.4-5.5 | EP5362QI | MPM3805GQB-33-P | 60% Smaller, 8% Higher efficiency, PG |
| 0.8 | 2.4-5.5 | EP5382QI | MPM38111GR-Z | 80% Smaller, 2% Higher efficiency |
| 0.8 | 2.4-5.5 | EP5388QI | MPM38111GR-P | 60% Smaller, 5% Higher efficiency |
| 1 | 2.4-5.5 | EN5312QI | MPM38111GR-P | 80% Smaller, 6% Higher efficiency |
| 1 | 2.7-5.5 | EN6310QA | MPM3810AGQB-AEC1-Z | 60% Smaller, 3% Higher efficiency |
| 1 | 2.7-5.5 | EN6310QI | MPM3810GQB-18-Z | 60% Smaller, 3% Higher efficiency |
| 1 | 2.4-5.5 | EP53A7HQI | MPM38111GR-P | 60% Smaller |
| 1 | 2.4-5.5 | EP53A7LQI | MPM38111GR-P | 60% Smaller |
| 1 | 2.4-5.5 | EP53A8HQA | MPM38111GR-Z | 60% Smaller, 4% efficiency |
| 1 | 2.4-5.5 | EP53A8HQI | MPM38111GR-Z | 60% Smaller, 4% Higher efficiency |
| 1 | 2.4-5.5 | EP53A8LQA | MPM3810AGQB-AEC1-Z | 20% Smaller, 4% Higher efficiency |
| 1 | 2.4-5.5 | EP53A8LQI | MPM38111GR-Z | 60% Smaller, 4% Higher efficiency |
| 1 | 2.4-5.5 | EN5311QI | MPM38111GR-Z | 80% Smaller, 6% Higher efficiency |
| 1.5 | 2.4-5.5 | EN5319QI | MPM3822CGRH-Z | 60% Smaller, 2% Higher efficiency |
| 1.5 | 2.4-5.5 | EP53F8QI | MPM3822CGRH-Z | 3% Smaller, 2% Higher efficiency |
| 2 | 2.4-5.5 | EN5322QI | MPM3822CGRH-Z | 60% Smaller, 1% Higher efficiency |
| 2 | 2.4-5.5 | EN5329QI | MPM3822CGRH-P | 60% Smaller |
| 3 | 2.4-5.5 | EN5337QI | MPM3833CGRH-P | 70% Smaller |
| 3 | 2.4-5.5 | EN5339QI | MPM3833CGRH-P | 60% Smaller |
| 3 | 2.4-6.6 | EN5335QI | MPM3833CGRH-P | 90% Smaller, 2% Higher efficiency |
| 3 | 2.4-6.6 | EN5336QI | MPM3833CGRH-P | 90% Smaller, 2% Higher efficiency |
| 3 | 2.5-6.6 | EN6337QA | MPM3833CGRH-Z | 70% Smaller |
| 3 | 2.5-6.6 | EN6337QI | MPM3833CGRH-Z | 70% Smaller |
| 3 | 2.7-6.6 | EN6338QI | MPM3833CGRH-Z | 40% Smaller |
| 4 | 2.7-6.6 | EN6340QI | MPM3860GQW-Z | 1% Higher efficiency |
| 4 | 2.5-6.6 | EN6347QA | MPM3840GQV-Z | 50% Smaller |
| 4 | 2.5 - 6.6 | EN6347QI | MPM3840GQV-Z | 50% Smaller |
| 6 | 2.4-5.5 | EN5365QI | MPM3860GQW-Z | 80% Smaller, 9% Higher efficiency |
| 6 | 2.4-5.5 | EN5366QI | MPM3860GQW-Z | 80% Smaller, 9% Higher efficiency |
| 6 | 2.5-5.5 | EN5367QI | MPM3860GQW-Z | 60% Smaller, 7% Higher efficiency |
| 6 | 2.4-6.6 | EN5364QI | MPM3860GQW-P | 70% Smaller, 4% Higher efficiency |
| 6 | 3.0-6.5 | EN6362QI | MPM3860GQW-P | 60% Smaller |
| 6 | 2.7-6.6 | EN6363QI | MPM3860GQW-P | 3% Higher efficiency |
| 8 | 2.5-6.6 | EN6360QA | MPM3683GQN-7 | 40% Smaller, 2% Higher efficiency |
| 8 | 2.5-6.6 | EN6360QI | MPM3683GQN-7 | 40% Smaller, 2% Higher efficiency |
| 8 | 3.0-6.5 | EN6382QI | MPM3683GQN-7 | 20% Smaller, 2% Higher efficiency |
| 20 | 4.5-16.0 | EM2120H01QI | MPM3695GRF-25-0022 | 40% Smaller |
| 20 | 4.5-16.0 | EM2120L01QI | MPM3695GRF-25-0022 | 40% Smaller |
| 30 | 4.5-16.0 | EM2030L01QI | MPM3690GBF-50B-T | 5% Higher Peak efficiency |
| 30 | 4.5-16.0 | EM2130H01QI | MPM3690GBF-50B-T | 5% Higher Peak efficiency |
| 30 | 4.5-16.0 | EM2130L01QI | MPM3690GBF-50B-T | 5% Higher Peak efficiency |
| 40 | 4.5-16.0 | EM2040N01QI | MPM3690GBF-50B-T | 5% Higher Peak efficiency |
| 40 | 4.5-16.0 | EM2140P01QI | MPM3690GBF-50B-T | 5% Higher Peak efficiency |
| 60 | 4.5-16.0 | EM2260P01QI | MPM3695GBH-100-0001 | 5% Higher Peak efficiency |
| 80 | 4.5-16.0 | EM2280P01QI | MPM3695GBH-100-0001 | 5% Higher Peak efficiency |
| 10 | 9.0-16.0 | EN29A0QI | MPM3695GMQ-10-0022 | 70% Smaller, PG |
Diese Kategorie im Deutschen TechForum zu Alternativen und Querverweisen bezieht sich auf Teile, die von Digi-Key nicht mehr angeboten werden, oder auf Teile, die veraltet sind. Unsere Ingenieurinnen und Technikerinnen haben die Spezifikationen für diese Teile überprüft und eine erste Empfehlung für einen möglichen Austausch abgegeben. Bitte überprüfen Sie die vorgeschlagenen Teil, um sicherzustellen, daß diese für Ihre Anwendungen als direkter Ersatz funktionieren.
