MOSFET equivalent to STP6NB25FP
I have a STP6NB25FP and am looking for an acceptable equivalent. This is for a washing machine control board. Thank you.
Hello Keegan. Welcome to the Technical Forum. That part appears to be obsolete. I found 742-SIHA15N80AE-GE3-ND on this link: SIHA15N80AE-GE3 Vishay Siliconix | Discrete Semiconductor Products | DigiKey
This is as close to an alternative I can find. I would recommend looking at the data sheet. There are some better ratings. Some are worse. There was not anything that I found exact. Maybe someone else will see something different than I have. This is the benefit of posting on the forum is you might get more than one option.
Thank you Verna_1353.
What about the FCPF7N60? Since this is for a motor controller board that is converting single phase to 3 phase power i’m guessing that the switching speed is important and from a little bit of searching on ChatGPT it looks like this one may perform better in that area? I am not an Electrical Engineer so if i’m way off please correct me.
Yes. That one looks like it would work also. Depending on when you search on what you can eliminate for options. This does not look bad. trade offs when there is not something direct. Though having more of the application this one does make more sense.
