This article is part of a guided learning series to explore real-world applications of MOSFETS and microcontrollers.
Canonical Article: How to Interface a Microcontroller with a Relay Using a MOSFET
Learning Companion (Q&A): Explore All Questions
You are reading: Question 6
What factors determine the turn on and off times for a relay?
Answer
The speed at which a relay opens and closes is governed by several factors including
Electrical time constant: The electrical time constant has a profound impact on the speed at which a relay opens and closes. The system is governed by the elementary tau = L/R equation, where inductance if the coils inductance and R is the coils intrinsic resistance plus the resistance of external circuitry. The circuit designer has some (limited) control over the electrical time constant.
Mechanical time constant: The mechanical time constant is a fixed property of the relay. It reflects the strength of the magnetic field, the distance the contacts must travel, and the general construction of the relay and associated magnetic fields.
Driver time constant: For the MOSFET, this time constant is a dominated by the RC time constant of the series current limiting resistor and the MOSFET’s gate.
Article by Aaron Dahlen, LCDR USCG (Ret.), Application Engineer at DigiKey
