Where should I look for PC motherboard connectors? I’m trying to find a female HD Audio header.
I believe it’s a standard 2.54 mm pitch female header that has been keyed by removing pin 8.
Hello wilkinsw,
One possible match is BCS-104-L-D-TE-001-ND
How does this one look to you?
No luck unfortunately. I’d need a 10 position with 9 loaded, but those search filters come up with a whole lot of “not in stock” connectors.
Could you use a standard 10-pin header and add the matching polarizing key? For instance, for the AMPMODU Mod IV series, we have these. Just press the plug into the appropriate hole.
