MPN: KX132-1211
  1. Please help to check Peak Package Body Temperature & No mounted within hours in MSL label for this part.
  2. Please help to check orientation, feeder size of carrier tape for dimension of width (in mm) & pitch (in mm). Below is example of feeder size (width & pitch) & orientation.
MPN: KX132-1211
Hi Supeng,
There isn’t any documentation readily available that gives that information you’re seeking.
I am checking further into this to see if the information can be obtained.
I will update you as soon as I get some feedback on it.
Thank you for choosing Digi-Key and have a wonderful day.
Hello Supeng,
Here is the information I was able to find on the manufacturer website.
MSL info: TN007 Package Handling Mounting and Soldering Guidelines (azureedge.net) , Tape and Reel info: TN008 PCB Design Guidelines for 2x2 LGA Sensors (azureedge.net)
Hope that helps.
