Multi AWG connector
I’ve been able to identify most of the connectors, which have been TE AMP. Can’t seem to come near on this one, no markings on it either. Any help in identifying it is appreciated, thanks in advance!
HI Jordan.R,
Welcome to the Tech Forum. There’s a pretty fair likelihood that this is a custom connector, noting the two different sized contacts between left and right sides, but is it possible to get another image or two from different angles? Based on the other image and the table you give, it’s apparently the connector for a vehicle VAC controller. In what vehicle(s) is it used?
Hi David,
Thanks for the welcome and information. I’d like to believe it isn’t custom, but it does appear that way. This is on a second generation dodge. This one in particular is 2000 Dodge Ram 1500.
