I just purchased https://www.digikey.com/en/products/detail/omron-electronics-inc-emc-div/SS-01GL-2T/6072053 these items and I cannot find the datasheet.
It shows datasheet but then directs me to a relay datasheet.
Also, my items seem to be weathered a bit, e.g. like they have been used previously.
Seth
P.S. I have the items still and I can test them but the leads on the limit switches seem to be used on the COM side.
Side note here…
Does anyone know where to find the screws that will fit in the attachment holes on these limit switches?
Seth
P.S. I have m3 machine screws which are a bit too large. I do not want to break them.
Hello @silver2row
Here is the link to the datasheet. According to it, use M2.3 mounting screws with plain washers or spring washers to securely mount the switch.
SS_Datasheet
And could you please share photos of the parts so we can verify their physical condition?
M2.3 screws. Thank you. Here are the photos of the COM side and the NC side of these limit switches…
The lighter color side is the COM side. It is almost like they were used or the finishing came off.
Seth
P.S. I am not exactly sure what this means… I tested the continuity of the switch with it depressed and then with it in its current state. They work. Anyway, thank you for any feedback.
