Having trouble identifying this 4pin connector. It connects from a UNIVIEW NVR board to the the SATA HDD. Its not a floppy connector. At wits end. TIA for any help.
Hi,
Welcome to the Digikey tech forum. Can you get us a pitch measurement? The space from the center of one contact to the center of the contact next to it. Also, any marking on the housing? They could be small and difficult to see but any numbers or letters could help us narrow options down.
TMtech,
Welcome to our tech forum! I do agree with Steve that we should get a pitch measurement and any other information available when identifying a connector like this. In this particular case however, I do believe I know which one it is. I will supply some options but please verify with the product pages and data sheets.
| DIGI-KEY PART # | 1175-51225-04-ND |
| MANUFACTURER | CNC Tech |
| DESCRIPTION | WIRE-TO BOARD HOUSING, 2.5MM, 4 |
| DATASHEET | 1175-51225-04-ND Spec |
OR
| DIGI-KEY PART # | 2057-25CH-B-04-ND |
| MANUFACTURER | Adam Tech |
| DESCRIPTION | CONN RCPT HSG 4POS 2.50MM |
| DATASHEET | 2057-25CH-B-04-ND Spec |
Please note that neither of these connector housings come with terminals. The part numbers for them are available near the bottom of the product pages linked above. Once you find the terminal in the bottom in the Associated Product section, you can repeat the process to find pre-crimped wires if they are available, as well as find recommended crimp tools for the terminals.
If you are not interested in the recommended crimp tool, you may be interested in a more universal option. You can take a look at this one.
| DIGI-KEY PART # | 1528-1683-ND |
| MANUFACTURER | Adafruit Industries LLC |
| DESCRIPTION | TOOL HAND CRIMPER 20-32AWG PA09 |
| DATASHEET | Datasheet |
I do find this helpful!
–Aaron
Many thanks, The manufacturer finally got back to me. Found the whole cable for 8 bucks shipped for free. It took them longer than expected to get back to me. Such an obscure little piece of necessary equipment.
Thanks again for your help.
I’m looking for the exact same NVR SATA power cable. What was the part number if you don’t mind sharing?
Hey, did you ever find the partnumber of that cable? I am looking for exactly the same cable but can’t find it anywhere…
