I am in need of a replacement for a NEC MR301-9HSL relay. A different brand, but equivalent in specs would be fine. Here is the datasheet for this relay. I tried to find one myself here at digikey, but I am not accustomed to ordering relays and didn’t see options for several of the specifications I need, so I decided to ask for help.
This particular version of the relay is 9V, high power (10A), “washtight”, and 0.8mm standoff. It has 5 pins.
Screenshot from the datasheet regarding specifications:
Thank you.
