we are looking for pin compatible replacement for Omron G2L-1-V or the SCHRACK TE 6-1393215-9 V23057-B0002-A201 (12V DC coil, 230V AC 8A)
does anyone know a suitable replacement, with the exact same pin layout
DigiKey offers a V23057-A0002-A201 as replacement, but that one is horizontal instead of vertical (and does not fit on the PCB with the other components)
Hello and welcome to the forum @Analock! I searched through our options for exact replacements with the pin layout, but unfortunately I haven’t found any. The absolute closest I found was this part number: 2449-J117F1CS12VDC-ND
You can see the differences in the pin layout on page 3 of the datasheet. It isn’t a perfect match, but it’s much closer than the horizontal mount that we have as a parametric equivalent.
