I can’t figure out what this bridge rectifier crosses over to or similar
Thanks in advance
Hello timurrenee and welcome to the DigiKey TechForum.
Based on what I could find regarding your part marking, it appears to be a KBJ80 bridge rectifier from SECOS. If that is correct, I did find the options linked HERE that may work as an alternative.
Make sure to review the documentation and specifications to ensure if they will work for your application.
Thanks,
I’m having a hard time finding the correct datasheet for this bridge rectifier as well.
Thanks again
I mean the current bridge rectifier I have.
