I have a blown bridge rectifier with the following markings that I need to replace but cannot identify; 7833, RS 262-084.
Thank you
Hello mfsb - welcome to the Forum. I’m sorry, I wasn’t able to identify the markings on your bridge rectifier. We do have parts in a similar package that you can take a look at, but I have no way of determining what the specifications of your diode are. Sorry I couldn’t be more helpful for you!
I did find the picture below on the internet. If you go off the 6A 800 we have some similar parts in different packages.
Bridge Rectifiers | Diodes | Electronic Components Distributor DigiKey If you need to keep the same package you could look at an option with a higher current rating.
The RS Electronics website gives Vishay GBPC608-E4/51 as an alternative. Hope this works for you!
We currently don’t have stock on GBPC608-E4/51. The options we have in stock at the moment would be rated higher for the Voltage and/or current. Bridge Rectifiers | Diodes | Electronic Components Distributor DigiKey Hope this helps!
