If someone could help me identify these (2) diodes and values by chance, I’d greatly appreciate it. Thanks.
Hello @pinzgauer,
In the pictures above you are missing the key identifier, and it maybe that it is just missing from the diodes all together. The number on top should be a 1N4001, 1N4002 etc and that last number would be the indicator of the value.
It appears from the marking that is is an SEP diode and they offer a wide variety of diodes and they are all the same size and only the part number marked on the Diode distinguishes the difference. If you are able to identify this number we can help to find a cross for this part.
Here is a link to similar products on the DigiKey site.
-Robert
I have a diode 1N4001 but also has the number 24 right above that. What is the 24 related too? I google it but cant find anything
Thanks
Hello @JCJC5555,
The 1N4001 will call out all the specifications. Some manufacturers have additional marking for date/lot or series information. I am not finding anything on a 24 that would indicate what it would mean. You should be safe replacing it with a 1N4001 diode.
-Robert
Ok thanks
J
