Hello… I am looking for replacement of a relay HKE HRS3-S-12V-A. It is a 4-pin relay. Thank you in advance.
FYI - from what I can tell the original part is readily available for $0.50 or less from other sellers on the internet. Substitute parts from other manufacturers seem to range from $1.50 to $4.00.
Thank you Paul. I checked on Amazon and found it goes from 15 to 25 each. Do you mind giving me the one you with $0.5? Thank you!
Kindly see the below relay for a potential replacement for this:
Part Number: OJ-SH-112HM,000 TE Connectivity Potter & Brumfield Relays | Relays | DigiKey
It was one of the usual super cheap china direct retailers at the top of a basic Google search. Sorry can’t remember which retailer it was off hand.
Thank you Paul and Kristof. Very much appreciated.
