Hi!
I have this relay on a welder thats in need of replacing. However its quite an old component so I wonder if anyone could help me find a similar replacement.
It has 6 pins.
Hello @flockisson
I have found part number 2961325-ND which is similar to the one in the photo, please check the datasheet to make sure this part will work for your application.
2961325 Phoenix Contact | Relays | DigiKey
Hi @flockisson ,
Otherwise, if you are able to pull the relay out of the board and take pin measurements, we may be able to get you other options.
Will look into it.
Thanks guys!
