Here are the hoses I need the mating connections for:
ABC03B-20P-4048
ABC06B-20P-4048
D38999/26MB98PA
D38999/26MB98PB
D38999/26TB98PB
D38999/26MB98PC
D38999/26MB98PD
D38999/26TB98PD
D38999/26MB98PE
D38999/26MB98PN
D38999/26MB98PE
D3899926WB98PN
D38999/26FA98PN
D38999/26WB98PA
D38999/26WB98PC
D38999/26WB98PD
Thanks
Mate for Part Number: ABC03B-20P-4048
ABC03P-20S-4048 TE Connectivity Deutsch Connectors | Connectors, Interconnects | DigiKey
Mate for Part Number: ABC06B-20P-4048
ABC06B-20S-4048 TE Connectivity Deutsch Connectors | Connectors, Interconnects | DigiKey
For the remainder of your connectors, I need to know for mates if you need a cable mounted or panel mounted connectors.
Cable mounted connectors. Thanks!
I was unable to identify cable mounted connectors for these connectors. From what I could find I have been only seeing panel mounted options.
Then could you give the mating connections for the panel mounted options?
I direct messaged you on this inquiry.
