i need help figuring out what this IC is and where i can get one. i think its a voltage regulator of some kind but looking up the text on it got me nowhere fast
The part number I pull up is TC1301ASSEVMF on this guide:
The bad part is I can’t find anyone that sells that part or even lists it. We have some of them in the series on this link:
Though I am not seeing the part that I find for this one. Though we can see if someone else is watching and has a better idea.
According to the datasheet as seen below, this is an available configuration but it is not a standard configuration. It may be possible to still order it but minimum order quantities and standard manufacturer lead times would apply. If this is something you would be interested in please contact applications.engineering@digikey.com for a non-catalog order.
To review the entire datasheet use the following link.
Dual LDO with Microcontroller RESET Function (microchip.com)
Unfortunately I was unable to locate a viable alternative option on our website.
