The JWLx1RA2A rocker switches available from DigiKey are rated for DC at 5A 72V according to manufacturer’s data sheet. In the same data sheet they note that to be recognized by UL, the switches should be ordered using a suffix /U-DC in the product code (to have the marking on the switch presumably).
Now the question is, can i make an order with such a specification?
Welcome to the DigiKey TechForum. I see on page 3 of 9 from the datasheet for that series there is a note stating:
Standard markings for JWM & JWL:
TV Rating, UL, CSA & VDE.
This JWL switch you’re looking for should already have the UL marking based on the note, you shouldn’t have to special order the switch to have the mark. What is the full part number of the switch you have in mind to order ?
