Hi, do NSYS3DC4320 and NSYS3DC4420 have mounting holes on the back?
If so, do these two models have the same hole patterns?
Thanks.
Thanks.
They do look like they have holes on the back in the corners. These two have different dimensions, so they won’t line up perfectly, but yes, the holes are in the same spots. They are in the four corners.
You can find more information such as CAD files, instructions, and details on Schneiders site:
Please note that neither part comes with a mounting plate. These can be found on this lengthy catalog datasheet:
You can use CTRL+F to filter out specific part numbers to help you navigate.
Thanks for the quick reply.
