4304.6092
------Question for 4304.6092 Please Put your question below------
What is the recommended hardware for 4304.6092?
Hello rferguson,
There is no recommended hardware listed for this module. They only have the mounting screw hole size in the mounting flange, as 3.2mm diameter, so an M3 screw should fit that size.
Depends on how you wish to mount it. That 3.2mm hole size would be suited to a flat-head M3 or possibly #4 screw.
From the datasheet:
