------Question for Z63000Z2910Z001Z48 Please Put your question below------
believe this component is very small in size.
Would it be possible to attach wires by soldering?
Also, could you please let me know what is the common or recommended method to supply power to it?
Thank you very much for your help.
Hello hagane08091516676,
The Datasheet say it is 12mm long x 4mm wide x 1.74mm thick.
The side has 2 solder pads, so it should be possible to solder wires to it.
Operating voltage range is 0~60V.
Please check the datasheet for this and other information. Also view the handling instructions, as you may damage the device if handled with your bare hands.
