O transformador 7508110151 substitui o 7508110159?
E quantos pinos tem de uma lado e do outro desse 7508110151?
Hello commercial1, welcome to the TechForum! I can’t seem to find any information on 7508110159 online. The only thing that comes up if you enter this onto our site is the 7508110151 you mentioned. If you know the specifications of the original, then you can compare it to this. According to the datasheet, there are 5 pins on each side. Pins 1, 2, 3, and 5 are the primary side and pins 9 and 7 are the secondary side. All other pins must be for mounting purposes.
