Looking for a substitute please. Manufacturer part# 481M-7138-3 = Description RPM7138.
Onkyo iR remote sensor, 5.5mm, 5v, carrier Freq 37.9Khz. DigiKey Part# RPM7138-R-ND https://www.digikey.com.au/en/products/detail/rohm-semiconductor/rpm7138-r/1642047
Hello @joey.brucia
Welcome to community!
Sorry, but there is no direct replacement available from the manufacturer’s end. However, we do have some other photodetectors available.
Please check the link below to see if any parts match your requirements.
Photo Detectors - Remote Receiver | Optical Sensors | Electronic Components Distributor DigiKey
The center band frequency of RPM7138-R-ND is 37.9Khz. The receiver allow frequencies above and below this to a degree.
Since 37.9KHz is very close to 38KHz, we can narrow down the possible options for replacement to this frequency.
I found BRM-2508-ND as a possible option for your replacement part.
Hi Steven,
Thank you for the explanation, I thought it had to be 37.9
I appreciate you.
Kind Regards
Joe Brucia
