This Product Selection Guide contains information to help select products in the Optical Sensors - Photo Detectors - Remote Receiver category on DigiKey.com
Products in the Remote Receiver Photo Detector family integrate a light sensitive element such as a photodiode with filtering and amplification functions, and are used as receivers for information transmitted via modulated infrared light. Most commonly found in devices such as televisions and other consumer products that are manipulated through the use of handheld remote controls, available devices vary in the extent of the filtering and signal processing they provide, resulting in various degrees of sensitivity and immunity to interfering ambient light.
SelectionCharacteristics
Specifications to determine which remote receiver photo detector is right for your application.
Sensing Distance: The distance within which the sensor can receive an input and produce a valid output.
B.P.F. Center Frequency: The frequency to which the part’s internal bandpass noise rejection filter is tuned; the carrier frequency of a modulated input that the part is designed to receive.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Current - Supply: This represents the maximum current to which a device will meet its given specifications. Exceeding this current may damage the device and/or other system components.
Orientation: Which side of the sensor it senses on.
ProductExamples
| MFR PART # | TSOP36236TT |
| DIGIKEY PART # | TSOP36236TTTR-ND - Tape & Reel (TR) |
| MANUFACTURER | Vishay Semiconductor Opto Division |
| DESCRIPTION | Remote Receiver Sensor 36.0kHz 45m Surface Mount |
| MFR PART # | BRM-2508 |
| DIGIKEY PART # | BRM-2508-ND |
| MANUFACTURER | American Bright Optoelectronics Corporation |
| DESCRIPTION | Remote Receiver Sensor 38.0kHz 20m Through Hole |
| MFR PART # | TSOP75336WTT |
| DIGIKEY PART # | TSOP75336WTTTR-ND - Tape & Reel (TR) |
| DESCRIPTION | Remote Receiver Sensor 36.0kHz 30m Surface Mount |
| MFR PART # | VSOP38336 |
| DIGIKEY PART # | VSOP38336TR-ND - Tape & Reel (TR) |
| DESCRIPTION | Remote Receiver Sensor 36.0kHz Surface Mount |
MediaLinks
Videos
Vishay OPTO 2V
Product Training Modules
Remote Control Infrared Receivers Vishay Semiconductor - Opto Division
Blogs
Detect Obstacles with an Arduino using an IR Sensor and LED
Understanding the Basics of Infrared Communications
How to Send and Receive IR Signals with a Raspberry Pi
TechForum
Choosing an IR Receiver
Choose IR receivers for part 511-1363-ND
Pioneer Car Radio IR Receiver Identification
Zilog ZMotion Detection Products
Vishay TSOP17 Series IR Receiver Module Alternatives
IR Receiver
