The contact socket referenced above has three barrels? One insulation, one wire and one orientation. My crimper iws 3220M will do 2 barrels at a time. Any clue what to do with the third barrel?
Also how to intert/remove socket contact from housing?
Thank you for your consideration
@DK_TechForum_drb
Referencing the below App. Spec. from TE conn.
Page 6 shows how the contact is meant to be crimped.
The inner/more forward “orientation” section is not altered by the crimping process.
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Specification+Or+Standard114-13000GpdfEnglishENG_SS_114-13000_G.pdf1-794610-1
Extraction tool 843996-6
843996-6 TE Application Tooling | Tools | DigiKey
TE lists, “An insertion tool is not required to insert contacts into receptacles.”
Thank you so much.
You kept me out of the deep water.
