Installed PADS Maker Edition, entered the license information as I received in the email, and as the program starts up, closes instantly with error " PADS Maker Schematic application has encountered a problem and needs to close."
Did not uncheck the boxes, I then clicked on OK and the app keeps closing immediately. I was never able to use it.
I also tried uninstalling then reinstalling the app, didn’t help.
Do you have a Dropbox already setup on this computer before installed PADS Maker?
If so, please follow these steps as a work around until we can get a fix out.
Uninstall PADS Maker and PartQuest utilities using Add/Remove programs
Go to C:/Users/your_user_name/AppData/Local/Dropbox and rename info.json to something else (ainfo.json for example)
Reinstall PADS Maker and PQ utilities
Set PartQuest to use Direct Download rather than Dropbox
