Installing your Panduit - Pan-Way Above Floor Raceway usually requires more than just the base AFR4BCOS6, depending on your application.
There are a number of fittings and accessories that make a Pan-Way Above Floor Raceway practical in many different situations, such as AFR4RAIW, which allows your raceway to make 90o turns. Below is a list of fittings, faceplates and accessories from the datasheet.
In addition there are some accessories available that work with the Pan-Way system, such as the AFR4WTROS which allows you to run your raceway through the wall.
Here are the accessories we carry:
Cables, Wires - Management | Wire Ducts, Raceways - Accessories | DigiKey
Applicable Part Numbers
| Digi-Key Part Numbers | ||
| 298-18813-ND | 298-18812-ND | OFR20CPOS8-ND |
| 298-18821-ND | 298-18811-ND | OFR20MT6-ND |
| 298-18814-ND | 298-AFR4BCIW6-ND | OFR20MT8-ND |
| 298-18815-ND | TB170EI6-ND | OFR20OB6-ND |
| 298-18822-ND | TB170IG6-ND | OFR20OB8-ND |
| 298-18819-ND | TB170IW6-ND | OFR20OG6-ND |
| 298-18818-ND | TB170EI10-ND | OFR20OG8-ND |
| 298-18816-ND | TB170EI8-ND | OFR20OS6-ND |
| 298-18820-ND | TB170IG10-ND | OFR20OS8-ND |
| 298-18817-ND | TB170IG8-ND | OFVR5MT6-ND |
| 298-AFR4WTROS-ND | TB170IW10-ND | OFVR5OB6-ND |
| 298-AFR4JB2SIW-ND | TB170IW8-ND | OFVR5OG6-ND |
| 298-AFR4CCIW-ND | TE70BIW10-ND | OFVR5OS6-ND |
| 298-AFR4TBLGOS-ND | TE70BIW8-ND | |
| 298-AFR4TRT70IW-ND | OFCR70MT6-ND | |
| 298-AFR4ECIW-ND | OFCR70OB6-ND | |
| 298-AFR4TBLGIW-ND | OFCR70OG6-ND | |
| 298-AFR4WTRIW-ND | OFCR70OS6-ND | |
| 298-AFR4RAIW-ND | OFR20CPMT8-ND | |
| 298-AFR4WTRBL-ND | OFR20CPOB8-ND | |
| 298-AFR4TBLGBL-ND | OFR20CPOG8-ND | |
| Manufacturer Part Numbers | ||
| AFR4CCBL | AFR4BCOS6 | OFR20CPOS8 |
| AFR4TRT70BL | AFR4BCBL6 | OFR20MT6 |
| AFR4CCOS | AFR4BCIW6 | OFR20MT8 |
| AFR4ECBL | TB170EI6 | OFR20OB6 |
| AFR4TRT70OS | TB170IG6 | OFR20OB8 |
| AFR4RABL | TB170IW6 | OFR20OG6 |
| AFR4JB2SOS | TB170EI10 | OFR20OG8 |
| AFR4ECOS | TB170EI8 | OFR20OS6 |
| AFR4RAOS | TB170IG10 | OFR20OS8 |
| AFR4JB2SBL | TB170IG8 | OFVR5MT6 |
| AFR4WTROS | TB170IW10 | OFVR5OB6 |
| AFR4JB2SIW | TB170IW8 | OFVR5OG6 |
| AFR4CCIW | TE70BIW10 | OFVR5OS6 |
| AFR4TBLGOS | TE70BIW8 | |
| AFR4TRT70IW | OFCR70MT6 | |
| AFR4ECIW | OFCR70OB6 | |
| AFR4TBLGIW | OFCR70OG6 | |
| AFR4WTRIW | OFCR70OS6 | |
| AFR4RAIW | OFR20CPMT8 | |
| AFR4WTRBL | OFR20CPOB8 | |
| AFR4TBLGBL | OFR20CPOG8 |
