Part Identification
0.2" header/connector pair, see attached. Digikey must have this part :wink:
Weclome to the Technical Forum. I was not sure if the terminal blocks are through hole like part number
ED2227-ND on this link: ED120/4DS On Shore Technology Inc. | Connectors, Interconnects | DigiKey . A surface mount version is 17-2383941-4CT-ND on this link: 2383941-4 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
I could find the pin headers also. I could only find a 2 position in the 5.08mm with part number 1849-1316-ND on this link: 31028102 METZ CONNECT USA Inc. | Connectors, Interconnects | DigiKey
You should be able to just put these side by side.
Awesome, thanks. Searching for Metz Connect I found what I wanted.
