Instead of using the traditional type of modular connector, where you have to cut the wires to length and then pass through a load bar or into the back of the modular connector. Pass-through Modular connectors from these series (Pass-Thru™, EZ-RJ45™, EZ-RJ45®) make it easy to strip off the outside jacket of the Cat wire and pass the wires through the housing. Then with a special crimp tool is used to terminate the wires in the modular housing and cuts off the excess wire.
Cat ratings supported:
Cat5
Cat5e
Cat6
Cat6a
Registered Jacks (RJ) supported:
6p6c (RJ11, RJ12, RJ14, RJ25)
8p8c (RJ45)
Cable Type Supported:
Round, Oval, Solid, or Stranded. Shielded or Unshielded.
Platinum Tools
Applicable parts
Platinum Tools numbers
202044J, 100047C, 202003J, 202051J, 202010J, 202052J, 100028C, 202036J, 202048J, 100003C, 100026C, 100010C, 202049J
Platinum Tools Datasheet
https://www.platinumtools.com/upload_doc/1488834653Plat-ezEXRJ45-TermSystem-ffr4a
Klein Tools, Inc
Applicable parts
VDV826-729, VDV826-703, VDV826-702, VDV826-728, VDV826-763, VDV826-762,
Klein Tools, Inc Datasheet
Winchester Interconnect
Winchester Interconnect Datasheet
Specialized Tools
