Hi,
I am searching for the attached link of this PCIE Bracket and heatsink product in DigiKey, but unable to find the exact part number, If incase the exact part is not available kindly share the alternate part.
Bracket link: (Amazon.com: Deal4GO 4U 12cm Full-Height Profile Bracket Backplate 54mm Mounting for Intel 750 P3500 P3600 P3700 M.2 SSD SATA PCIe Adapter SAS Cards : Electronics)
Heatsink Link: (Amazon.com: WWZMDiB 4Pcs 40mm Heatsink Back Side Thermal Conductive Tape 40mm x 40mm x 11mm Heat Sink : Electronics)
Please do the needful.
Regards,
Nandhini A.
Hello @nandhini_a
The closest bracket I could find to that one on Amazon is part number 9200-19 from Keystone but it does not have the angled mounting brackets, so it may not work with the intel 750. Please check the drawing and datasheet to see if it will work for your application.
For the heatsink we have 3 similar parts, but they are black not gold, and you can see them in the link below.
Heat Sinks | Thermal | Electronic Components Distributor DigiKey
Here’s a link to some additional heatsinks which may work for you, listed in order of thermal resistance from lowest to highest, with lower thermal resistance being better at removing heat.
All of them have the 40mm x 40mm footprint with adhesive backing. Some spread out wider above the mounting surface, so you would need to check for clearance in your particular application.
